Subthreshold OTA Design
IntuitiveAnalog
Member level 2
Member level 2
I have to design an OTA in subthreshold region as a part of a project .
The specifications are not very stringent , I am only concerned about low power dissipation around 100's of nW and supply voltage less than 1v.
I have searched literature and found that gm/id approach can be used to design low power circuits but I am unable to adjust w/l using gm/id method .
If anyone could through some light on this issue , I will be very much thankful.
The circuit of OTA is attached.
First of all thanks for reply erikl
I have read Paul Jespers' book and I have got some idea about gm/id methodology .
If I talk about the attached OTA ,I know that from slew rate specification tail current can be found and so w/l of current source, similarly from gain bandwidth gm of input differential pair transistors can be calculated and so its w/l .
The main problem is arising in sizing of pmos of differential pair and output transistors .
If you can give idea about how to decide gm or gm/id ratio of pmos ,then it will be quite helpful for me.
Thanks
First show your design with the W/L ratios which you have calculated so far, and tell your process or its technology current.
First of all I have taken tail current as 200nA and gm/id for current source as 20 . From gm/id vs id/(w/l) curve w/l is coming out to be 0.5 . As far as input stage is concerned as current is 100nA in each branch , I have chosen gm/id as 25 which gives w/l as 2.5 . This condition also fulfills bandwidth requirement which is coming out to be around 2 Mhz (If mirror ratio is taken as 5).
Now I am stuck at this point , don't have idea how to proceed with sizing of output and pmos differential pair transistors.
I am attaching the curves used.
You didn't reveal your process nor its technology current; from your gm/id and current values I just can guess it's a 0.18 or 0.13µm process, so its µn/µp ratio will be about 3..4 . For the pmos transistors' ratio I'd try such a multiplication factor: w/l ≈ 8 .. 10 and play with this ratio as to get the right voltage (≈ half supply voltage) @ OUT.
Yes erikl I am using 0.18um process.
You mean to say that w/l for input pmos transistors should be 3-4 times that of nmos transistors?
what about output stage transistors?
AMSA84
The circuit I am using can be easily found in literature as 'three current mirror OTA'.
For symetric response the gm of both nmos and pmos fets should be the same, so Wp/Wn should be equal to Kn/Kp, where Kn,p are the current gain factors of fets in your process. Of course in real life You need to made trade-off between current gain factor and intrinsic capacitances of both transistors - dependly to process it could be in range between 2 and 5.
From my modest experience the input pair should works in moderate inversion - if=1 or 10 (for modern process - refer to Sansen lecture on last ISCAS conference about designing in 20nm and beyond) and try to bias current mirrors in moderate/strong inversion - if in the range of 10-50.
if is of course the ratio of drain current over specific current. For better results include mobility degradation by lateral and vertical electric field.
First of all thanks for reply Dominik
If I bias even current mirrors in subthreshold , then besides low power consumption will there be any other benefit as well?
Thanks
