You can't get rid of that issue with subthreshold mosfets because VT has an exponential dependence. If you're looking for constant current, look into using BJTs since the built in potential doesn't significantly change over process. But a constant gm bias is typically better for amplifiers, and has a lot less variation--that's the way I would go about it.
