Feb 8, 2005 #1 S saras Junior Member level 3 Joined Oct 26, 2004 Messages 27 Helped 2 Reputation 4 Reaction score 1 Trophy points 1,283 Activity points 284 Dear all, While simulating an antenna with HFSS, i get this error message and the simulation stops: Seeding mesh, process mesh3d: subprocess "%3" died unexpectedly does anybody knows what causes this problem and how it must be solved? thanks in advance sara
Feb 9, 2005 #2 W wlcsp Full Member level 3 Joined Aug 16, 2004 Messages 184 Helped 22 Reputation 44 Reaction score 10 Trophy points 1,298 Activity points 1,511 saras said: Dear all, While simulating an antenna with HFSS, i get this error message and the simulation stops: Seeding mesh, process mesh3d: subprocess "%3" died unexpectedly does anybody knows what causes this problem and how it must be solved? thanks in advance sara Click to expand... Maybe you have a very small object in your structure. The aspect ration between the smallest and largest objects should not exceed 1e6 I guess.
