promach
I have already added so many assert() at https://github.com/promach/UART/blob/development/rtl/test_UART.v , but during induction test, formal verification tool leads me straight to https://i.imgur.com/GNUAl7z.png which is the second last state during UART receiving mechanism at line 258 ?
Line 258 is about verifying the parity bit received against the parity value calculated from the received data, however, my coding failed this assert() test.
I am not sure what other assert() I should add before parity assertion. Could anyone advise ?
Code Verilog - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 module test_UART(clk, reset, serial_out, enable, i_data, o_busy, received_data, data_is_valid, rx_error); parameter INPUT_DATA_WIDTH = 8; parameter PARITY_ENABLED = 1; parameter PARITY_TYPE = 0; // 0 = even parity, 1 = odd parity input clk; input reset; // transmitter signals input enable; input [(INPUT_DATA_WIDTH-1):0] i_data; output o_busy; output serial_out; `ifdef FORMAL wire baud_clk; wire [(INPUT_DATA_WIDTH+PARITY_ENABLED+1):0] shift_reg; // Tx internal PISO `endif // receiver signals wire serial_in; output reg data_is_valid; output reg rx_error; output reg [(INPUT_DATA_WIDTH-1):0] received_data; `ifdef FORMAL localparam NUMBER_OF_BITS = INPUT_DATA_WIDTH + 3; // 1 start bit, 8 data bits, 1 parity bit, 1 stop bit wire [($clog2(NUMBER_OF_BITS)-1) : 0] state; // for Rx `endif UART uart(.clk(clk), .reset(reset), .serial_out(serial_out), .enable(enable), .i_data(i_data), .o_busy(o_busy), .serial_in(serial_in), .received_data(received_data), .data_is_valid(data_is_valid), .rx_error(rx_error) `ifdef FORMAL , .state(state), .baud_clk(baud_clk), .shift_reg(shift_reg) `endif ); assign serial_in = serial_out; // tx goes to rx, so that we know that our UART works at least in terms of logic-wise `ifdef FORMAL localparam Rx_IDLE = 4'b0000; localparam Rx_START_BIT = 4'b0001; localparam Rx_DATA_BIT_0 = 4'b0010; localparam Rx_DATA_BIT_1 = 4'b0011; localparam Rx_DATA_BIT_2 = 4'b0100; localparam Rx_DATA_BIT_3 = 4'b0101; localparam Rx_DATA_BIT_4 = 4'b0110; localparam Rx_DATA_BIT_5 = 4'b0111; localparam Rx_DATA_BIT_6 = 4'b1000; localparam Rx_DATA_BIT_7 = 4'b1001; localparam Rx_PARITY_BIT = 4'b1010; localparam Rx_STOP_BIT = 4'b1011; localparam NUMBER_OF_RX_SYNCHRONIZERS = 3; // three FF synhronizers for clock domain crossing localparam CLOCKS_PER_BIT = 8; reg had_been_enabled; // a signal to latch 'enable' reg[($clog2(NUMBER_OF_BITS + NUMBER_OF_RX_SYNCHRONIZERS)-1) : 0] cnt; // to track the number of clock cycles incurred between assertion of 'transmission_had_started' signal from Tx and assertion of 'data_is_valid' signal from Rx reg transmission_had_started; reg had_just_reset; reg first_clock_passed; initial begin had_been_enabled = 0; cnt = 0; transmission_had_started = 0; had_just_reset = 0; first_clock_passed = 0; end always @(posedge clk) begin first_clock_passed <= 1; end wire [($clog2(NUMBER_OF_BITS-1)-1) : 0] stop_bit_location; assign stop_bit_location = (cnt < NUMBER_OF_BITS) ? (NUMBER_OF_BITS - 1 - cnt) : 0; // if not during UART transmission, set to zero as default for no specific reason wire [($clog2(NUMBER_OF_BITS)-1) : 0] stop_bit_location_plus_one = stop_bit_location + 1; always @(posedge clk) begin assert(cnt < NUMBER_OF_BITS + NUMBER_OF_RX_SYNCHRONIZERS + 1); assert(stop_bit_location < NUMBER_OF_BITS); if(($past(first_clock_passed) == 0) && (first_clock_passed == 1)) begin assert($past(stop_bit_location) == (NUMBER_OF_BITS-1)); assert($past(&shift_reg) == 1); end end always @(posedge clk) begin if(reset) begin cnt <= 0; had_been_enabled <= 0; transmission_had_started <= 0; end else if(baud_clk) begin if(transmission_had_started) begin cnt <= cnt + 1; end transmission_had_started <= had_been_enabled; // Tx only operates at every rising edge of 'baud_clk' (Tx's clock) end else begin if(enable && (!had_been_enabled)) begin cnt <= 0; assert(cnt == 0); had_been_enabled <= 1; assert(state == Rx_IDLE); assert(data_is_valid == 0); if(had_just_reset) begin assert(&shift_reg == 1); end assert(serial_out == 1); assert(o_busy == 0); end else if(transmission_had_started) begin if(cnt == 0) begin // start of UART transmission assert(state < Rx_STOP_BIT); assert(data_is_valid == 0); assert(shift_reg == {1'b0, 1'b1, (^i_data), i_data}); // ^data is even parity bit assert(serial_out == 0); // start bit assert(o_busy == 1); end else if((cnt > 0) && (cnt < (NUMBER_OF_BITS-1))) begin // during UART transmission assert(state < Rx_STOP_BIT); assert(data_is_valid == 0); assert(shift_reg[stop_bit_location_plus_one] == 1'b0); assert(shift_reg[stop_bit_location] == 1'b1); assert(o_busy == 1); end else if(cnt == (NUMBER_OF_BITS - 1)) begin // end of UART transmission assert(state < Rx_STOP_BIT); assert(data_is_valid == 0); assert(shift_reg == 0); assert(serial_out == 1); // stop bit assert(o_busy == 1); end else begin // if(cnt > ((NUMBER_OF_BITS + 1)*CLOCKS_PER_BIT)) begin // UART Rx internal states if(state == Rx_START_BIT) begin assert(data_is_valid == 0); assert(serial_in == 0); assert(o_busy == 1); assert(cnt == (NUMBER_OF_BITS + NUMBER_OF_RX_SYNCHRONIZERS + 1)*CLOCKS_PER_BIT); end else if((state > Rx_START_BIT) && (state < Rx_PARITY_BIT)) begin // data bits assert(data_is_valid == 1); assert(o_busy == 1); assert(cnt == (NUMBER_OF_BITS + NUMBER_OF_RX_SYNCHRONIZERS + (state - Rx_START_BIT) + 1)*CLOCKS_PER_BIT); end else if(state == Rx_PARITY_BIT) begin assert(data_is_valid == 0); assert(serial_in == ^i_data); assert(o_busy == 1); assert(cnt == (NUMBER_OF_BITS + NUMBER_OF_RX_SYNCHRONIZERS + state + 1)*CLOCKS_PER_BIT); end else begin // if(state == Rx_STOP_BIT) begin // end of one UART transaction (both transmitting and receiving) assert(state == Rx_STOP_BIT); assert(data_is_valid == 1); assert(serial_in == 1); assert(o_busy == 0); assert(cnt == (NUMBER_OF_BITS + NUMBER_OF_RX_SYNCHRONIZERS + 1)*CLOCKS_PER_BIT); cnt <= 0; had_been_enabled <= 0; end /* else begin assert(state == Rx_IDLE); assert(data_is_valid == 0); assert(serial_in == 1); end*/ end end else begin // UART Tx and Rx are idling, still waiting for baud_clk cnt <= 0; assert(cnt == 0); assert(state == Rx_IDLE); assert(data_is_valid == 0); assert(serial_out == 1); if(!had_been_enabled) begin assert(&shift_reg == 1); end end end end always @(posedge clk) begin if(reset) begin had_just_reset <= 1; //assert(); end else begin had_just_reset <= 0; if(!had_just_reset) begin if((had_been_enabled) && (!$past(had_been_enabled))) begin assert(!$past(o_busy)); assert(o_busy); end else if((had_been_enabled) && ($past(had_been_enabled))) begin assert($past(o_busy)); assert(o_busy); end else begin assert(!$past(o_busy)); if($past(enable)) begin assert(o_busy); end else begin assert(!o_busy); end assert(serial_out == 1); end end end end always @(posedge clk) begin if(reset | o_busy) begin assume(enable == 0); end if(enable | had_been_enabled) begin assume($past(i_data) == i_data); end end always @(posedge clk) begin assert(!rx_error); // no parity error if(data_is_valid) begin // state == Rx_STOP_BIT assert(received_data == i_data); assert(cnt < NUMBER_OF_BITS*CLOCKS_PER_BIT); end if((!had_just_reset) && (state <= Rx_STOP_BIT) && (first_clock_passed) && (transmission_had_started) && ($past(transmission_had_started)) && ($past(baud_clk))) begin assert(cnt - $past(cnt) == 1); end end `endif endmodule
