stuck with bootloader for PIC 16f877a
ram1cal
Newbie level 3
india
i don't know y but i tried all the bootloaders which are found in net but all failed..
non of them detecting my PIC (using max232)
i tried bootloader from microchipc 9.7 (https://www.microchipc.com/PIC16bootload/index.php)
but its display a msg
searching for bootloader
after tat no response
i checked my circuit
nothing is wrong (unfortunately my multimeter got repaired i just continuity of wire all good but cant check appropriate current rating i hope current cant be big problem)
then i kept the led on the crystal but it is not glowing (I'M NEW TO HARD COMPONENTS OF PIC I'M JUST A STUDENT)
i tried to download some other prog (after tat boot file fail using icprog106B)
my led (but not bright as led on supply) on the o/p of max232 (+5)
blink but if try to read tat from pic non of the led blink..
also i read most previous threads of other ppl and solution but i have no idea on this prob.
tell me
1)what that its show is my pic dead..
how i can i check it i bought a week before its new..
is there any other way to check the pic
2)y that boot loaders are not functioning
3)wat can i do next to for boot programmer[/i]
spiralbrain
what programmer are you using?
Do you verify the contents of the PIC after its programmed?
try reading the PIC to see if it has code in it.
if its dead, its most likely to read all zeroes and will not erase or program.
keith1200rs
Super Moderator
Staff member
Yorkshire, UK
You need a PIC programmer to load the bootstrap program before you can use the bootloader. If you haven't load the bootstrap program you will get nowhere.
Keith.
