[SOLVED] String + int code doesn't work
andihong
Member level 1
i have a code for arduino that need a string with variable to redirect the value to mysql
here the example of code.
int input = sht1x.readTemperatureC();
i want to get the variable inside the string on HttpPost.
here the code
httpPOST("http:xxx.com", 80, "/tes.php", "(i want to get it inside here)", msg, 50);
httpPOST("http:xxx.com", 80, "/tes.php", "input="+input+"", msg, 50);
the code doesn't work, is there any way to convert it ?
Try converting input to string and pass the string to httpPOST() like this.
httpPOST("http:xxx.com", 80, "/tes.php", str, msg, 50);
str is the string which holds the int value converted to string.
For better help, zip and post the Arduino sketch and necessary Arduino libraries.
Try this
String myStr = String(input);
httpPOST("http:xxx.com", 80, "/tes.php", myStr, msg, 50);
Try this
it doesn't work.
i want to post the parameter to send it through php file.
httpPOST("http:xxx.com", 80, "/tes.php", "", msg, 50);
if i am give the value, its work,
example : httpPOST("http:xxx.com", 80, "/tes.php", "humidity=70&value=60", msg, 50);
but if i want to change the value 70 and 60 to a variable that i get from the sht11, it doesn't work..
please help.
I asked you to Zip and post the Arduino sketch and necessary libraries.
https://www.instructables.com/id/PART-1-Send-Arduino-data-to-the-Web-PHP-MySQL-D3js/?ALLSTEPS
oh ya sorry i forgot to upload the libraries and arduino sketch,
Attached below are the libraries.
and the arduino sketch
#include "SIM900.h"
#include <SoftwareSerial.h>
#include "inetGSM.h"
#include <SHT1x.h>
#define dataPin 10
#define clockPin 11
SHT1x sht1x(dataPin, clockPin);
InetGSM inet;
int k = 0;
int j = 0;
char msg[150];
boolean found = false;
char data;
int numdata;
char inSerial[50];
int i = 0;
boolean started = false;
void setup()
  Serial.begin(9600);
  Serial.println("Arduino Started");
  if (gsm.begin(2400)) {
    Serial.println("\nstatus=READY");
    started = true;
  else Serial.println("\nstatus=IDLE");
  if (started) {
    if (inet.attachGPRS("internet", "wap", "wap123"))
      Serial.println("status=ATTACHED");
    else Serial.println("status=ERROR");
    delay(1000);
void loop()
  int suhu;
  int temp_c;
  int temp_f;
  int humidity;
  temp_c = sht1x.readTemperatureC();
  temp_f = sht1x.readTemperatureF();
  humidity = sht1x.readHumidity();
 inet.httpPOST("andi.pcr.ac.id", 80, "/tessuhu.php", "cahaya=[COLOR="#FF0000"]1000[/COLOR]&kelembaban=[COLOR="#FF0000"]70[/COLOR]&suhu=[COLOR="#FF0000"]30[/COLOR]", msg, 50);
 serialswread();
  delay(3600000);
void serialswread() {
  gsm.SimpleRead();
here i want to change the colored red text with the variable temp_c, suhu , and humidity that values from sensor.
  • GSM-GPRS-GPS-Shield-GSMSHIELDv1.zip
Attached Project File below:
  • GSM-GPRS-GPS-Shield-GSMSHIELD.zip
The values being passed to httpPOST() is wrong.
httpPOST(const char* server, int port, const char* path, const char* parameters, char* result, int resultlength)
See example project and pass arguments according to the function.
how to make an arguments with String and then convert to char*?
You are passing sting to const char* parameters
You have to see GPRS example sketch and find out what parameters have to be sent. There are const strings.
