sinrey
Junior Member level 1
Are you looking for a more efficient and streamlined way to work with audio in your projects? Just look at the SIP2701V network audio module. This versatile and self-contained module is designed to be easily embedded in OEM products, providing a robust and reliable audio solution for a wide range of applications.
One of the main features of the SIP2701V module is its ability to encode and decode SIP protocol and RTP audio streams from the network. This ensures smooth and seamless audio transmission, even in complex and demanding applications. Through the standard RJ45 network interface, you can easily upgrade the firmware online remotely to keep your audio system up-to-date and safe.
The SIP2701V network audio module is built on the basis of ARM+DSP architecture, and uses high-speed industrial-grade chips to achieve the best performance. With a start-up time of ≤1 second, the module is ideal for applications where speed and responsiveness are critical.
But the SIP2701V module is not only fast and reliable, but also versatile. It has an audio line-out port that lets you connect it to powered speakers for sound amplification. With the audio line-in port, you can even connect an external powered microphone for talkback functionality.
Overall, the SIP2701V Network Audio Module is the perfect choice for anyone looking to simplify their audio solutions. With its powerful performance, reliable transmission and rich features, this module is sure to meet all your audio needs.
You can view relevant information through our website https://www.sinrey.com/, or send us your requirements, and we will customize the functions you want for you
