Catalyst
Full Member level 3
Hi all,
I have created a 4 turn inductor spiral (attached). I simulated it from 0.1 MHz to 20 MHz. The Inductance values are pretty close to experimental, however over the frequency sweep the inductance value seems to drop rapidly from 0.1 MHz to about 1 MHz then starts to slowly increase again. I having a problem understanding why there is a sharp fall in the inductance value at the lower frequencies.
Can anyone help to explain this? (See the attached graph)
Much appreciated
Cat
Much appreciated
Cat
