Strange problem with a new design-maybe a GND issue?
udir
Newbie level 5
Newbie level 5
Hi There
I am experiencing a weird problem with my newly design.
Its basically a simple carrier board with SOM that operates a touch screen and 2 other applications.
This device is Fed from simple 12 V DC power adaptor and is said to be "floating".
When I started testings and an external lab, they used a probe that generates a low voltage signal in a high frequency and touched either the power supply cable when its connected to the machine or the touch screen itself, and it suddenly froze! when i touch the screen nothing happens.....only restart helps.
I have no idea why it happens as the device is suppose to be floating.any idea how to attack this?
Ron
With devices said to be "floating", then connecting another device referred to a ground often causes problems. I think a "floating" device allows to ground one of the DC lines, then the connection becomes safe. Make sure the positive and negative DC lines have a blocking capacitor(s) connected. The best is a parallel combination of a 100 uF and 0.1 uF capacitors . Usually the negative DC line is best to be GND.
