strange problem with 16f877a
zero2004
Member level 1
Hi every body
I had bult a pwm application with 16f877a, the circuit work normaly when i tuch the ground wire of dc power supply!!!! , except that it doesn't work, the circuit on a brid bord.
thanks alot for helping me
You do know you should tie the MCLR pin (using say a 10k resistor) to the +5 rail ?
Hi liquias
I connect it with 10k resister well
The problem is surely of hardware. Recheck all the connections on bread board. Any of the loose connection can cause this.
NIKS
Hi
I suspect that the problems is in power supply unit, there is a harmonics on dc that affect to the pic, any suggestion for good and reliable dc circuits
thanks
Most probably a power supply problem. Try turning off the brown-out reset and see if there will be any change.
Place decoupling caps (0.1uF) from the PIC supply pins to ground as well as an electrolytic 10uF as close to the PIC as possible and turn off the BOR.
Hope this helps.
Tahmid.
Hi every body
thanks for your replays, but the problem still exists
thanks again
