strange problem during frequency measurement.
hemnath
Advanced Member level 3
Chennai
PIC18F2520, CCS C compiler.
I'm measuring the frequency and depending on the frequency, LED output changes. When i comment the below 2 lines in the program, frequency reads correctly. But when i uncomment those lines, it reads wrong frequency. But i want to read and write the eeprom data. Is it possible? below program fails to read the correct frequency during reading and writing eeprom? Please help.
HTML:
flag1 = read_eeprom(FLAG_ADDRESS);
write_eeprom(FLAG_ADDRESS,flag);
HTML:
#include "18f2520.h"
#fuses H4, NOWDT
#use delay(clock=16000000)         // 4Mhz crystal with PLL enabled. 4Mhz * 4 => 16Mhz
#define     output_pin    PIN_A4
#define  	LED  		  PIN_C4
#define FLAG_ADDRESS 		10
#define FLAG_STATUS_ADDRESS     20
int8 old_f, f = 0;
int16 temp_data;
int32 local;
int8 HIGH;
int8 flag1;
int16 isr_ccp_value;
int16 current_ccp_value;
int32 frequency;
int flag;
#int_ccp1
void ccp1_isr(void)
	int16 current_ccp;
	static int16 old_ccp = 0;
	f++;
	current_ccp = CCP_1;   // Read the 16-bit hardware CCP1 register
	isr_ccp_value = current_ccp - old_ccp;
	old_ccp = current_ccp;        // Save the current ccp value for the next pass.
void main()
set_tris_a(0x00);
set_tris_c(0x00);
set_timer1(0);                               //   Timer value to 0
setup_timer_1(T1_INTERNAL | T1_DIV_BY_1);    //   Timer1 internal & 1:1 Prescaler
setup_ccp1(CCP_CAPTURE_RE);                  //   Looks for Rising edge
clear_interrupt(INT_CCP1);                  //   disables the CCP1 interrupt
enable_interrupts(INT_CCP1);                //   enables the CCP1 Interupt
enable_interrupts(GLOBAL);                  //   Enables global interrupt
HIGH = 1;
while(1)
current_ccp_value = isr_ccp_value;
enable_interrupts(GLOBAL);           		 //   enable interrupts
	while(old_f == f);
	old_f = f;
	if(f < 64)
	       do
 	         temp_data=current_ccp_value;
	       } while (current_ccp_value!=temp_data);
	       local += temp_data;
	else
    	disable_interrupts(GLOBAL);
		frequency = (int16)((640 * 393822) / (local));
	if((frequency < 2000))
		output_high(LED);
		output_high(output_pin);
		flag = 1;
	flag1 = read_eeprom(FLAG_ADDRESS);                // read the value in eeprom address - flag
	if((frequency > 2000) && (frequency < 3000) && (flag1 == 1))
		output_high(LED);
		flag = 1;
	if((frequency > 3000))
		output_low(LED);
		output_low(output_pin);
		flag = 0;
	if((frequency > 2000) && (frequency < 3000) && (flag == 0))
		output_low(LED);
		flag = 0;
	local = f=old_f=0;
Thanks in advance :)
