pikulin03
Junior Member level 1
My task was to build very simple buck DC-DC converter with input voltage in the range 15-30V, output - 12V.
The key idea was to build the control circuitry not using control IC chips, but by means of usual OP AMPS and comaprators in order to be free to modify any of its blocks.
The operation frequency was chosen very low to avoid high frequency effects, as the converter has to be used for some aducational purposes.
Amplifier used is the NE5534
Comparator used is the LM311
The ramp generator was build using the simple 555 circuit.
All control circuits are powered from the imput voltage through the 7812CT.
When I first tested the converter- ir seamd OK- the output voltage was about 12V, as Vin was changed from 15 to 30V. But than I looked at the waveforms and was surprised.
ALL waveforms in the converter contained the high-frequency harmonics and rather high spikes.
Including the RAMP voltage, the power voltage of IC's, output error voltage and even input voltage from the ordinary lab DC power supply.
The mentioned spikes cause comparator switch at very high frequences.
These spikes are shown on the pictures I've attached.
I've added bypass capacitors 0.1u between the VCC and groung of every IC, changed the capacitors at 7812CT to higher values. Tried several lab. power supplies- however the spikes are still present!
Maybe somebody has an idea- where do they come from?
I would appreciate any help!
