strange behaviour of state machine in vhdl
pejotr
Newbie level 1
Warsaw
In the following code, which is well known 2 process state machine, if i comment line "if rising_edge(CK) then", corresponding "end if" and remove CK from sensitivity listi of e0 process it produces some strange results, why ?
library ieee;
use ieee.numeric_std.all;
use ieee.std_logic_1164.all;
use work.binary_converters_pack.all;
entity operation is
	generic ( n : natural := 8);
	port ( M,Q		: in std_logic_vector(n-1 downto 0);
		   RDY,CK	: in std_logic;
		   RES	: out std_logic_vector(n-1 downto 0);
		   BSY  : out std_logic);
end entity operation;
architecture operation_arch of operation is
	type state_type is (S0, S1);
	signal res0 		: std_logic_vector(n-1 downto 0);
	signal a0, q0, m0	: unsigned(n-1 downto 0);
	signal current_state, next_state : state_type;
	begin
	e0: process(CK, current_state) is
		begin
			for i in 0 to 6 loop a0(i+1) <= a0(i); end loop;
			a0(0) <= RDY;
			case current_state is
				when S0 =>
					next_state <= S1;
					BSY <= '1';
				when S1 =>
					next_state <= S0;
					BSY <= '0';
			end case;
		end if;
	end process e0;
	clk0: process(CK) is
		begin
			if rising_edge(CK) then RES <= std_logic_vector(a0); current_state <= next_state; end if;
	end process clk0;
end architecture operation_arch;
You didn't tell, what you mean with strange results...
However, you have packed some code into the normally asynchronous part of the state machine (case current state..), that
hasn't anything to do with state machine operation. In so far, it isn't actually a state machine problem.
The real problem is, that the shift operation inside the loop only works in a clock synchronous process.
