devil6600
Full Member level 5
Hi all,
i've very strange problem while writing to external eeprom 24lc512. its connected to 18f4550 with 4.7k pullups. eeprom data is sent through USB from PC
i am writing eeprom in chunk of 28bytes, writing to first 28 location is ok but when i write to 29th location the 28th location byte gets corrupt. when i try to correct it by writing a single byte at 28th location then the 27th location byte gets corrupt.
i have no idea why eeprom is not working as expected. below is the code:
eeprom dump, see at last 28th byte should be FF but its D9:
when i specifically try to correct 28th byte then the 27th byte gets corrupted
can you please help me solving this issue
Thank You
for aa = 3 to 62 step 2
temp_add = USBRXBuffer[aa]
gosub hexconvert
edata[0] = temp_add * 16
temp_add = USBRXBuffer[aa+1]
gosub hexconvert
edata[1] = temp_add
edata[2] = edata[1] + edata[0]
prg_block[cc] = edata[2]
cc = cc + 1
next aa
I2cwrite SDA,SCL,CONTROL,address[4],[str prg_block\cc]
pause 10
FF
FF
FF
FF
FF
FF
FF
FF
FF
FF
FF
FF
FF
FF
FF
FF
FF
FF
FF
FF
FF
FF
FF
FF
FF
FF
FF
FF
D9
FF
FF
FF
Thank You
