Storing images in a variable
KPJYOTHIS
Newbie level 3
I want 2 variables each stores a set of images say trueset and testset.then compare each images in the testset with the trueset to findout the similarities using the functions such as overlap,IOF functions etc.Then have to rank the images in the testset.Is there any efficient matlabcode for this.
KPJYOTHIS
Newbie level 3
Can the variable I store number of images or a single image?
kalyanasv
Full Member level 4
NY
If you want to process two separate images, I would simply store it in two variables. Its easier to handle logically.
That having said, matlab treats I as a matrix. So you can add, subtract do all the image processing you want on it. i.e. store multiple images.
KPJYOTHIS
Newbie level 3
Actually i want 2 variables where each variable holds a set of images.Then want to compare each images from one variable to all images in the second variable to find out the similarities.
kalyanasv
Full Member level 4
NY
Try this:
N = 100
IMAGES = cell(1,N);
FNAMEFMT = 'image_%d.png';
for i=1:N
  IMAGES{i} = imread(sprintf(FNAMEFMT, i));
end
andre_teprom
Super Moderator
Staff member
Brazil
You can read separatelly.
The above code was mentioned just for template.
ima1 = imread('trueset.jpg');
ima2 = imread('testset.jpg');
In example posted at refered link - now transcripted here - ima1 and ima2 could receive each figure :
% Template matching code based on correlation
% Threshold should be in [0,1]
% YRP 2005
function Corr = TemplateMatching(ima1,ima2,threshold)
s = size(ima1);
% Performs Correlation
corr = StandardCorrelation(ima1,ima2);
% Dislays image
figure(1); imagesc(ima1); axis image;
% Displays correlation
figure(2); imagesc(corr); axis image;
% Display detection results
% Creates an RGB image
ima3 = zeros(s(1),s(2),3);
% Allocates Red plane to scene
ima1 = double(ima1);
ima3(:,:,1) = double(ima1-min(min(ima1)))/(max(max(ima1))-min(min(ima1))); %/512 as data must be in [0,1]
% Allocates Green and Blue to correlation
max(max(corr))
ima3(:,:,2) = (corr > threshold);
ima3(:,:,3) = (corr > threshold);
figure(3); imagesc(ima3); axis image;
