Store data time and settings on eeprom
cnandha19
Member level 3
HTML:
    int datetime[5];
    unsinged char lanugage;
    void main()
    eeprom_value = 0;
   spi_eeprom_Write(0x0000,&eeprom_value,sizeof(eeprom_value));
   Initialsetup = intilize_initialsetup(Initialsetup);
  lcdClear();
  spi_eeprom_Write(0x0001,&Initialsetup.language,sizeof(Initialsetup.language));
  Initialsetup.ChoiceOfLanguage =  spi_eeprom_Read(0x0001);
     //to store language  how to check whether this setting is stored on not and after turn off and on microcontroller how it will retain
					if(strcmp(Initialsetup.units,Get_Unitsmeterstrings(Initialsetup.ChoiceOfLanguage))==0)
						eeprom_value = 1;
						spi_eeprom_Write(0x0002,&eeprom_value,sizeof(eeprom_value));
					if(strcmp(Initialsetup.units,Get_Unitsfeetstrings(Initialsetup.ChoiceOfLanguage))==0)
						eeprom_value = 0;
					settime(Initialsetup.datetime[3],Initialsetup.datetime[4]);
					setdate(Initialsetup.datetime[2], Initialsetup.datetime[1], Initialsetup.datetime[0]);
					spi_eeprom_Write(0x0003,Initialsetup.password,sizeof(Initialsetup.password));
I am storing values on eeprom how to check whether this setting is stored on not and after turn off and on microcontroller how it will retain
How to check:
Immediately after you have written the EEPROM cells read them back to verify its contents.
how it will retain:
EEPROM is non volatile memory. It needs no power to keep the contents.
In your software you need a routine to read back the EEPROM values.
Hint:
Consider to use something like a checksum or CRC with your EEPROM data, then you are able to check validity of the EEPROM contents after power up.
Klaus
Is it correct to write and read to select Language as English in menu drive i have to write "ENGLISH" to EEPROM for that i had done below is it right way to write name and read it on default ascii
   char store_value;
	unsigned char eeprom_value = 0;
    char defaultascii[5];
    char name[10] ={"English"};
	sysclk_init();
	irq_initialize_vectors();
	cpu_irq_enable();
	AT25160B_init();     // SPI  initialization
	initLcd();
	lcdClear();
	lcdMoveCursor(0,0);
	lcdPrintStr("EEPROM TEST");
	eeprom_value = 0;
	eeprom_value = spi_eeprom_Read(0x0000);
	if(eeprom_value != 1)
		spi_eeprom_Write(0x0003, name, sizeof(name));
	defaultascii[0] = spi_eeprom_Read(0x0003);
	defaultascii[1] = spi_eeprom_Read(0x0004);
	defaultascii[2] = spi_eeprom_Read(0x0005);
	defaultascii[3] = spi_eeprom_Read(0x0006);
	defaultascii[4] = spi_eeprom_Read(0x0007);
	defaultascii[5] = spi_eeprom_Read(0x0008);
	lcdMoveCursor(1,2);
	lcdPrintChar(defaultascii[0]);
	lcdMoveCursor(1,3);
	lcdPrintChar(defaultascii[1]);
	lcdMoveCursor(1,4);
	lcdPrintChar(defaultascii[2]);
	lcdMoveCursor(1,5);
	lcdPrintChar(defaultascii[3]);
	lcdMoveCursor(1,6);
	lcdPrintChar(defaultascii[4]);
	lcdMoveCursor(1,7);
	lcdPrintChar(defaultascii[5]);
	delay_ms(1000);
What data you store in the EEPROM is completely up to you.
You may store ASCII characters as string like "English".
or you may choose a single byte variable. Where you decide the function upon it´s value. Then 0x00 could represent english language and 0x01 could represent spanish language.
Klaus
if((keyvalue==ENTER)&&(status == 0))
			delay_ms(100);
			Initialsetup.datetime[0] = Initialsetup.value_store;
			Initialsetup.datetime[0] = Initialsetup.datetime[0] % 100;
			spi_eeprom_Write(0x0022,&Initialsetup.datetime[0],sizeof(Initialsetup.datetime[0]));
			year= Initialsetup.datetime[0];
			lcdClear();
			lcdMoveCursor(1,5);
			lcdPrintStr("OK");
			delay_ms(5000);
			read_value = spi_eeprom_Read(0x0022);
			lcdClear();
			lcdMoveCursor(1,5);
		       print_integer(read_value);
			delay_ms(5000);
If i read this value means i am getting '0' in LCD display instead of year 2014
