[ARM] STM32 LwIP with STM32CubeMX, is it the right way ?
bianchi77
California
Is it the right way to define IP address 10.0.0.5 ??
void MX_LWIP_Init(void)
  IP_ADDRESS[0] = 10;
  IP_ADDRESS[1] = 000;
  IP_ADDRESS[2] = 000;
  IP_ADDRESS[3] = 5;
  NETMASK_ADDRESS[0] = 255;
  NETMASK_ADDRESS[1] = 255;
  NETMASK_ADDRESS[2] = 255;
  NETMASK_ADDRESS[3] = 000;
  GATEWAY_ADDRESS[0] = 10;
  GATEWAY_ADDRESS[1] = 000;
  GATEWAY_ADDRESS[2] = 000;
  GATEWAY_ADDRESS[3] = 1;
    /* Initilialize the LwIP stack */
  lwip_init();
  IP4_ADDR(&ipaddr, IP_ADDRESS[0], IP_ADDRESS[1], IP_ADDRESS[2], IP_ADDRESS[3]);
  IP4_ADDR(&netmask, NETMASK_ADDRESS[0], NETMASK_ADDRESS[1] , NETMASK_ADDRESS[2], NETMASK_ADDRESS[3]);
  IP4_ADDR(&gw, GATEWAY_ADDRESS[0], GATEWAY_ADDRESS[1], GATEWAY_ADDRESS[2], GATEWAY_ADDRESS[3]);
  /* add the network interface */
  netif_add(&gnetif, &ipaddr, &netmask, &gw, NULL, ðernetif_init, ðernet_input);
  /*  Registers the default network interface */
  netif_set_default(&gnetif);
  if (netif_is_link_up(&gnetif))
    /* When the netif is fully configured this function must be called */
    netif_set_up(&gnetif);
  else
    /* When the netif link is down this function must be called */
       netif_set_down(&gnetif);
HI
you can work with rl-arm and keil ide.
Rl-arm is software solution for arm microcontrollers and you can work the network ,file system,usb and so on . but if you want to work with that you should get the licsience for that.
keil website is : www.keil.com
