Register Log in
Steps for installing Cadence IC5141 on Fedora 9
elmolla
Full Member level 2
installing cadence
Hi All,
This is based on the topics
https://www.edaboard.com/viewtopic.php?t=297992
https://www.edaboard.com/viewtopic.php?t=213946[
I'm just going to write the steps mentioned in other topics to save the space; this is more like a description of how to get things working
1. Get the USR5 and Base CDs and extract them in a directory, say
/tmp/cdsinstall/
2. Set posix compliance by typing "export _POSIX2_VERSION='199209'"
3. Go to CDROM1 in the USR5 extraction and type ./SETUP.SH to run the installation, let the installation directory, for this post, be /usr/local/cdstree
4. If you were not able to start softload to complete the installation just go to
/usr/local/cdstree/install/bin.lnx86 and type ./softload to continue the installation as mentioned in topic https://www.edaboard.com/viewtopic.php?t=297992 after step 9.
5. Adjust your .bashrc ,or .cshrc file, as in the topic https://www.edaboard.com/viewtopic.php?t=213946[
to be
CDS_ROOT=/usr/local/cdstree
CDS_INSTALL_PATH=$CDS_ROOT/tools/dfII/
export CDS_LIC_FILE=$CDS_ROOT/share/license/license.dat
export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:$CDS_ROOT/tools/lib:$CDS_INSTALL_PATH/lib
export PATH=$PATH:$CDS_ROOT/tools/bin:$CDS_INSTALL_PATH/bin:$CDS_ROOT/tools/spectre/bin
export CDS_Netlisting_Mode=Analog
6. Source your .bashrc file and try to run icfb, just type source .bashrc then icfb &, if things work out then you're clear :), if not continue with the installation, this depends on the libraries you used in your Fedora installation.
7. Most probably you'll get an error for libXp.so.6 or a similar one. To overcome this extract the files attached in this topic and install them using the command 'yum install', i.e. to install library MyLib1.rpm type: yum install MyLib1.rpm.
So, extract this file, yum install all the rpms in it and then yum install libXp and libXp-devel.
8. If you had installed the above correctly, you'll get some font error when trying to run icfb, this is because the xorg-x11-fonts are missing.
The above libraries were missing in my installation, so if you still have others missing then go to /usr/local/cdstress/tools/dfII/bin and type ldd ./icfb.exe to check the missing libraries. You'll find the word "Not Found" beside the names of the missing libraries, you can download those missing libraries separately. Just google the missing library's name and you'll find a link to its RPM download.
9. To install the missing fonts type
yum list available | grep xorg-x11-font
This'll get a list of all the missing xorg-x11-font, install the missing "normal" fonts, there are other non-english fonts, no need for them. Just yum install the missing fonts.
10. If you've done the above step correctly, icfb will run now smoothly :D
hardcore84
Newbie level 5
fedora cadence
Hi elmolla, i follow your instructions but i get the GLIBC2 error message in Fedora 9 when i try to run icfb. Any suggestion?
Thanks.
tanker
Newbie level 1
cadence ic5141
Hi elmolla,i follow your instructions but your libs install wrong.
" yum install libXt-1.0.4-5.fc9.i386.rpm
Loaded plugins: refresh-packagekit
Setting up Install Process
Parsing package install arguments
Examining libXt-1.0.4-5.fc9.i386.rpm: libXt-1.0.4-5.fc9.i386
libXt-1.0.4-5.fc9.i386.rpm: does not update installed package.
Nothing to do "
Any solution? Tks.
Added after 23 minutes:
[root@localhost ~]# icfb
/bin/sh: error while loading shared libraries: libdl.so.2: cannot open shared object file: No such file or directory
Added after 1 minutes:
/ecad/IC50/tools/dfII/bin/icfb.exe: relocation error: /ecad/IC50/tools/dfII/bin/icfb.exe: symbol errno, version GLIBC_2.0 not defined in file libc.so.6 with link time reference
elmolla
Full Member level 2
ic5141 fedora
Hi tanker,
This means you have this library already installed, but you need to install other required packages. better go to the executable icfb directory and use the ldd command to find out the the missing packages.
_SquiD_
cadence fedora
hi there, elmolla
I have encountered some kind of problem when starting the installation ... can you tell me what I've done wrong.
After specifying the installation path and after the installation checked for the installation CD's these lines appeared ... and seemed to me that aren't ok :
Checking data files...
Executing control programs (pre-load) ...
load_pkgs: ./install/pkgs/dfIIdb50.41-s103lnx86.exe: /bin/csh: bad interpreter: No such file or directory
SL-10:Installation of dfIIdb50.41-s103lnx86 declined by control program (PRE_LOAD)
dfIIdb50.41-s103lnx86 will not be installedload_pkgs: ./install/pkgs/dfIIdb50.41-s103lnx86.exe: /bin/csh: bad interpreter: No such file or directory
Checking IC5141 lnx86 ISR 200712140835 CDROM # 1  ...
loading SEVcdnWrap10.00-p001 ..............
Installation of SEVcdnWrap10.00-p001 complete
Total Installation 1 % done
After the installation continued ... but I presume that some files are missing. I tried the installation in Fedora Core 9.
Thanks in advance, _Squ!D_
elmolla
Full Member level 2
icfb bad interpreter: no such file or directory
Hi Squid,
Are you using csh during the installation or bash?
Did icfb run after installation or not?
Best regards,
Mohammed Omar
_SquiD_
cadence fedora 10
elmolla said:
Hi Squid,
Best regards,
Mohammed Omar
I'm using bash I presume. How can I make a difference ?
Yes, icfb ran after the installation finished ... it opens the splash screen ... it says some warning messages and automatically closes. I can't do a thing .... and I thought this behavior was caused by those warning messages in the installation progress (see upper post).
_Squ!D_
elelab
USA
cadence ic5141 fedora
Must use csh. In Fedora 9, it's tcsh.
Using tcsh, no those error message during installation.
one solution for icfb running problem:
add/remove software -> search "x11-fonts" -> check each fonts and apply
then icfb run without the error - "X Error of failed request: BadName (named color or font does not exist) "
I just made it. Thanks for posted information.
elmolla said:
Hi Squid,
Best regards,
Mohammed Omar
okguy
Full Member level 6
China
The proper font (at least for me) is :
xorg-x11-fonts-ISO8859-1-75dpi-...
OkGuy
Toggle Sidebar
