anassar
Newbie level 6
how to install cadence ic5141
This topic is about installing Cadence IC5141 on Centos5 distribution of Linux.
This post augments the topic at the following link:
This installation was implemented on a Sony VAIO laptop. Installation of IC5141 failed on Fedora Core 9 run by this hardware. As recommended by Cadence, RHEL-4 or 5 is the operating system to use with IC5141. To the best of my knowledge, the closest relative to RHEL-5 is Centos5, on which I managed to install IC5141.
I followed the installation procedure detailed in the link above with one modification:
Instead of installing the missing libraries and fonts after installing IC5141, I had to install them first. This is because installation of IC5141 seems to have messed up the gcc version required by Python upon which the yum utility is working, which made the yum utility to cease working after IC5141 is installed and cannot be used to query missing libraries and install them.
Before installing IC5141, use the command "yum list xorg-x11-font*" to list all available xorg-x11 fonts. All available such fonts are listed with a flag indicating whether or not they are installed on the system. Use "yum install font" to install all xorg-x11 fonts not currently installed on the system as indicated by the list returned above., where font is the font package to be installed.
Also, the "yum list libXt*" and "yum list libXp*" and "yum list libXext*" bring you lists of all graphics libraries that may be missing in your system and that are needed by IC5141. If the lists returned by those commands indicate that those libraries are installed on the system, then there's no need to install them. Otherwise, use "yum install library" to install the missing libraries of them.
After all missing libraries/packages have been installed, just follow the procedure referred to by the link above without modification.
