Stepping Motors. What size is good to replace a RC Servo?
wickedweed
Newbie level 5
Hi. Recently we made some VoIP kiosks for my client and he wanted the wire attached to the handset retract back into the kiosk every time someone finishes using it. I made a mechanism which is basically a RC servo modded for continuous rotation & controlled by a PIC. The whole thing works well except for the noise. You know how loud servos can be.
I am now thinking of using steppers instead but have no idea if the smaller ones (like those found in DVD rom drives that spins the disc) are strong enough to wind the cable (basically a headphones cable). I have never worked with steppers before and will greatly appreciate any pointers and inputs. Thanks! :)
nandhu015
Advanced Member level 5
India
No, you have to find some bigger one
wickedweed
Newbie level 5
thanks. u r right. just realized that they are brushless motors instead of steppers. the only stepper inside is the one that moves the laser head up n down but think it's definitely too weak for my intended purpose. guess i'll have to look for bigger ones.
