Mbox314
Newbie level 5
Hello,
I am trying to get a 4 cell Lithium battery pack to work with a 12 volt inverter. The inverter I am using has a maximum voltage of 15 volts and a minimum voltage of 11volts. The battery that I am using to power the inverters has a nominal voltage of 14.7 volts and a voltage of 16.5 volts when fully charged.
What kind of options do I have for getting the inverter to work with the battery voltage?
The inverter will output 120 volts and 1 amp so the inverter will be drawing about 10 amps from the battery.
How can I drop the battery voltage down by a volt or two so it will be within the voltage range accepted by the inverter?
Thank you,
Thank you,
