Stepper Motor wit mCU
eng.Electronic
Junior Member level 3
Egypt
mcu controlled stepper motor
Hello All ,
How can i calculate the delay for a stepper motor controlled with AT89c52 ?
Thanks In Advance
mostafa_elwakeel
Member level 1
egypt
hi ;
i cant understand you what is the delay you mean?
by the way you can use ics l297 and l298 to drive stepper motor
thx
banh
Advanced Member level 1
eng.Electronic said:
Hello All ,
Thanks In Advance
do you mean the output waveform : squarewave and what should it frequency be?
In this case you should inspect the spec of the stepper.
there is a relationship between speed and torque: higher speed -> lower torque and vice versa.
So once you know the torque you need, you can apply the appropriate frequency.
eng.Electronic
Egypt
Hello
Thanks at first for replay...i am connceted mCU with a Stepper motor via a Driver..
to move the motor in angel 20 degree..but i cant define the delay time between each sequence of the bits in the code..So..how can i calculate this delay_time ?
( By The Way ..it first times it work correctlt then moving in a random angels)
Thanks
fireball003
Full Member level 3
If you can generate signal then, what's the big deal? if you use the simplest algorithm-
loop{
PIN1set
delay(time)
PIN1clr
PIN2set
delay(time)
PIN2clr
PIN1set
delay(time)
This will create signal sequence.
I guess you are in trouble with generating sequence and wire configuration. what is your stepper motor type?how many wires are there? which driver are you using?
the following sites may be helpful to you-
https://www.cs.uiowa.edu/~jones/step/
https://www.epanorama.net/links/motorcontrol.html
