stepper motor vhdl codes
Sweta25
Junior Member level 1
Hi I am trying to write codes for half step for stepper motor and I am using a clock divider so as I can choose the frequency of the motor. But I am getting errors, any help would be appreciated. Thanks in advance :)
library IEEE;
use IEEE.STD_LOGIC_1164.all;
use IEEE.STD_LOGIC_unsigned.all;
use IEEE.STD_LOGIC_arith.all;
entity driver is
port(
clk : in STD_LOGIC;
start : in STD_LOGIC;
Dout : out STD_LOGIC_VECTOR(3 downto 0)
end driver;
architecture driver of driver is
component clkdiv
port
mclk : in STD_LOGIC;
clr : in STD_LOGIC_VECTOR(0 downto 0);
clk94: out STD_LOGIC
end component;
signal clk94 : STD_LOGIC;
begin
U1 : clkdiv
port map
mclk => mclk, clr => clr, clk94 => clk   <--------- ERROR
process ( clk, start)is
variable m: std_logic_vector ( 2 downto 0);
begin
if (start ='1')then
if (rising_edge (clk)) then
m:= m +1 ;
end if;
end if;
case m is
when "000" => Dout <= "1000";
when "001" => Dout <= "1100";
when "010" => Dout <= "0100";
when "011" => Dout <= "0110";
when "100" => Dout <= "0010";
when "101" => Dout <= "0011";
when "110" => Dout <= "0001";
when others => Dout <= "1001";
end case;
end process;
end driver;
Codes for clk div
library IEEE;
entity clkdiv is
port(
clk94: out STD_LOGIC;
clk : out STD_LOGIC_VECTOR (2 downto 0)
end clkdiv;
architecture clkdiv of clkdiv is
signal q: STD_LOGIC_VECTOR (23 downto 0);
begin
process (mclk ,clr(0))
begin
if clr(0)= '1' then
q <= X"000000" ;
elsif mclk 'event and mclk = '1' then
q <= q + 1;
end if ;
end process;
clk(0)<= q(0);
clk(1)<= q(1);
clk(2)<= q(21);
clk94 <= q(19);
end clkdiv;
errors:
# Error: COMP96_0078: driver.vhd : (51, 10): Unknown identifier "mclk".
# Error: COMP96_0078: driver.vhd : (51, 23): Unknown identifier "clr".
# Error: COMP96_0133: driver.vhd : (51, 10): Cannot find object declaration.
# Error: COMP96_0133: driver.vhd : (51, 23): Cannot find object declaration.
# Error: COMP96_0413: driver.vhd : (51, 37): Actual of mode 'in' cannot be assigned to formal "clk94" of mode 'out'.
# Error: COMP96_0104: driver.vhd : (51, 2): Undefined type of expression.
# Error: COMP96_0104: driver.vhd : (51, 16): Undefined type of expression.
# Compile failure 7 Errors 0 Warnings Analysis time : 16.0 [ms]
mclk and clr are not defined. You are assigning clk which is an input port to clk94 from clkdiv which is an output. You cannot do that...
Considering that you are making the poor design decision to generate a clock from the output of a counter, you should at the very least synchronize the inputs to the FSM driven by that clock.
Re: stepper motor vhdl codes
Check your clkdiv.vhd code. There is port mismatch, it means "clkdiv.vhd has 2 input,2 output but in driver.vhd component declaration only 2 input and one output. Then mclk and clr is not declared anywhere in driver.vhd so check it
Did you find this post helpful? Click: Yes
