I am trying to build a robot which requires around 2000 oz-in of torque at speeds of up to 100 RPM. I was looking at the 3334 stepper motor, it can handle the torque no problem but says it has a max RPM of 25. Is this the max RPM at the continuous torque or unloaded? If it is at the continuous torque, is there a way to find out the actual max RPM. Finally if it turns out that the motor is insufficient can you recommend a motor that would be more suitable?
