stepper motor conrolled with micro controlled
almasee
Junior Member level 1
oman
good evening,
i want program for my micro cotroller AT89C51
the motor should run
anticolck
clockwise
icrsease speed
decrease speed
my regards
the mask
Member level 2
jordan
hi
iam from jordan i can help you i can run it in pic16f877a and ican help you generalley
but iwant now if you can write code in your controller and which your stepper motor and what you now about this subject
pranam77
Advanced Member level 5
INDIA
the mask said:
hi...am from jordan i can help you i can run it in pic16f877a and ican help you generalley
Generally 50% of the work is done is the OP know to write the code. IF he writes it, what help you'll do with his hardware / assembling part sitting in Jordhan?
the mask
Member level 2
jordan
hi...
i try to help and i try understand what he want exactly
i think he want procure code so i can help he and how you knew he write the code
i know you best me in controller so if you want help do it and i will listen
