Help
Advanced Member level 2
stepping up battery voltage
Dear All,
Currently I’m doing for hobby testing. I plan to use the solar energy to charge my handphone.
I have few concerns:
1) I have done some testing with my old handphone charger, when the charger is changing the battery i measure the voltage is 3.8Volt when full charged. May i know what the voltage range 3.3 Volt or 5Volt to charge the handphone battery?
2) As we know the solar power is not constant supply. So, i plan to use MAX1724EZK33-T(Iout = 150mA) or MAX1674(Iout = 200mA) IC to charge my handphone battery. This 2 IC is it suitable for charger? Please advice..
3) I would like to take the challanging to add one data reading function in my charger. This function is measure the Voltage and Current and then stores the reading data in EEPROM. On the uC side I think i should use AT89S2051 because the operating range can be 2.7~5.5V, so use charger voltage to supply the board IC.
If i at those function in the charger, i guess the current consumption for the board will be high, not sure the Step-up Converters IC can handle the power.
Please anyone can give some advice?
Thank you,
Help
Dear All,
Thank you,
Help
