ericmar
Full Member level 5
step up power supply
I plan to use either 4 cells of alkaline batteries (4 x 1.5V) or an AC adapter of +9V @ 2.2A as the main power source and step-up, step-down this power source to create few different voltage supplies (+12V, +3.3V and +1.8V).
My problem is should I be stepping down the +1.8V from the main power source or stepping down from the regulated +3.3V (which is first step-down from the +9V). This is because the voltage difference between +3.3V and +1.8V is only +1.5V while the voltage difference between the +9V and +1.8V is as high as +7.2V. I think there will be waste of energy for such a conversion, right?
How should I arrange it such that the power efficiency is optimum?
I decided to use a boost converter to step up the power source to +12V. As for the step-down part, I am not sure whether to use a Linear Regulator or a Buck converter to perform the step-down. Linear Regulator is easy to be used but the efficiency maybe lower. A buck converter can achieve much better efficiency but more complicated to build. Any suggestions?
Thanks for any help in advance.
Regards,
eric
Regards,
eric
