Step recovery diode (SRD)simulation
ttse7
Junior Member level 2
step recovery diode
Hi all,
I would like to do a impulse circuit based on SRD. In agilent ADS2005A, there is no SRD model library. How can I model SRD in ADS2005A.
Thanks
ttse7
J0hn
Member level 2
step recovery diodes
Ya, i also have the same problem finding the model for SRD to be used in ADS. I guess is an area that very few ppl go into it. It will be a great if we can model the SRD in ADS so that the designing of the comb generator or multiplexer will be much easier.
ttse7
ads step recovery diode
so which srd are you using? I use the one from M-Pulse.
J0hn
Member level 2
ads model of step recoverty diode
Hmm, i previously playing with M/A-com SRD.... in die-form.. Next monday, i will be playing with M-pulse SRD...
So far, i fail to model the SRD in ADS. I simply try to play ard the cap and inductor value and try to come out a comb response with the min loss.
