Golden Electronics
Full Member level 5
Is any one working on static voltage stabilizer using IGBT ? If yes please share controller & how igbt switch AC waveform?
Note: This feature currently requires accessing the site using the built-in Safari browser.
U mean to say that using Dc generate ac & connect to output using transformer. U just google static voltage stabilizer u get many mfgnever seen it done, but one scenario could be to feed your main AC through a low voltage transformer secondary, say 24 V at 40 A. Feed its primary with PWM generated AC voltage such that the main output is constant.
Frank
