Static power is a function of the process and transistor type. You can reduce it by:
1. Using a low-leakage process.
2. Selecting cells that have high Vt (threshold voltage) transistors if available.
3. Use voltage islands and shut down islands not in use.
4. Use fewer gates / transistors.
