Static comparator Versus Dynamic one
tottistone
What are the differences? And what are the advantages of each over the other?
Thanks.
here the one i/p of comparator is fixed in static one.... in the case of dynamic it changes wrt o/p..... dynamic ones are generally done so improve their noise immunity......
this terminology is also used from power dissipation point of view.
static comparators needs a dc current for its operation... but can be used as a continuous time comaprator. ie no need of a strobe signal.
Dynamic comparators does not require dc current... but this needs a strobe signal to latch the input.
hope this helps
fred
I'd say that dynamic comparators always rely on positive feedback to speed up the decision. This positive feedback is implemented as a latch. Because of this they need a clock/strobe signal to start the comparison.
Static comparators are open-loop, without feedback. The comparison is always active, so no clock/strobe signal is needed.
The best comparators use an open-loop first stage and later they use a positive-feedback stage.
    V
