sabu31
Advanced Member level 1
Dear All,
I have designed a Flyback converter 85-245 Vac to 12V ,4A using UC 3842 controller. As per design, the startup resistor is supposed to be 100kOhms. However, the converter didnt start. But when I reduced the startup resistor to 24k 4Watt(using a paralle combination of 68k 2Watt and 39k 2 Watt), the converter is working. However, the startup resistor is getting heated after about running for 1min. What could be the reason for this startup resistor heating and how can i reduce this
