Starting with VHDL and newbie
baby_1
Advanced Member level 1
Starting with VHDL, Im newbie
Hello
i want to learn VHDL Programming and work with high frequency digital gate.
could you tell me
1-what is the best reference and book for learn VHDL?
2-what is the best and easiest Compiler ?
3-what is the inexpensive and good IC for work with vhdl?
Thanks
You will see many good references when you search for "vhdl tutorial" on google.
The best way to learn it would be by designing something and implementing it on hardware. You can download design software which includes compiler (synthesizer) and implementation tools from major FPGA vendor's website.
For example,
ISE Webpack from xilinx
Quartus-II from Altera
Libero from Actel
They even come with a simulation tool.
For implementation, I think the best way would be buying one of development kits from these major vendors. I've used Xilinx Spartan-III, Altera Cyclone-III and Actel Igloo development boards, they were relatively cheap (around 100 dollar) and very easy to use...
Reactions: baby_1
    baby_1
Start with "Digital Logic and Microprocessor Design with VHDL" by Enoch Hwang. It's a great book for a thorough understanding of the fundamentals of digital design using VHDL. Personally I thought the book was very readable with plenty of example problems and that the author has a clear way of expressing ideas.
Reactions: baby_1
    baby_1
The author has made the "VHDL summary" appendix available on his website, and unfortunately the book uses the non-standard libraries "std_logic_arith", "std_logic_unsigned" etc.
For a beginner I recommend a book that uses "numeric_std", which has been the IEEE standard for about 20 years.
The library has a significant impact on the code, so the selection is important.
I want every beginner to know that there is a choice to be made here.
At work, we are only allowed to use numeric_std.
It is much easier to learn numeric_std from the beginning than to switch to it later.
I accept that some designers use std_logic_arith, but I think it should an active choice and not decided by randomly getting a book to learn VHDL.
Look at "The designer's guide to VHDL" by Peter J. Ashenden:
https://www.amazon.com/Designers-Guide-VHDL-Systems-Silicon/dp/1558602704
Unfortunately, it is normally impossible to know which libraries a book uses without looking at some example pages.
Reviews normally don't mention this.
http://www.amazon.com/Designers-Guide-VHDL-Systems-Silicon/dp/1558602704
I agree "The designer's guide to VHDL" is a good book, but one for a seasoned FPGA/VHDL designer. For a beginner I don't necessarily like the fact that the author doesn't differentiate enough between constructs and concepts used for simulation vs. synthesis vs. modeling, it can lead to a lot of confusion. And for a beginner I would place more emphasis on digital design fundamentals rather than language specifics. For a seasoned engineer the book is an invaluable resource however. Also, proper use of the language's libraries is very important, I do agree.
Also for the OP as far as "good ICs to work with".. I would start out with a development board
You should find what you need at either of these:
http://www.digilentinc.com/
http://www.terasic.com.tw/en/
Reactions: baby_1
    baby_1
thanks to all
now what books you suggest that can be useful from beginning to professional (history of ICs, Technology,Digital Design and ...)?
