I have a good experience in Embedded Systems and Computer Architecture.
Also I have a fair knowledge about Digital communications
I have a job to implement some DSP code for Digital communication on TigerSharc .
The design inputs will be Matlab code or ANSI C implementation for the system.
My Question is How and from Where to start?
As u are using tiger sharc, u can use the their tool set to begin.
Basically I recommend that you start using the simulators as soon as possible. You can develop and test your code in the VisualDSP environment
I agree, try the simulation and some simple samples provided by ADI, you will catch up soon if you know the theory already. Try, and try, that's it.
