Yarrow
Member level 2
I am designing some standard cells in 65 nm and I was wondering if it is normal to design standard cells using minimum design rules or DFM rules?
My thought is that one would like to make the standard cells as compact as possible, but to do this one violates the recommended design rules. As I understand it, the recommended design rules are there in order to reduce the possibility of shorts, avoid high RC in contacts/vias, etc.
Is anyone familiar with were I can find yield information when it comes to usage of minimum design rules vs. recommended design rules? For example, what kind of yield can I expect from 30k standard cells designed using minimum design rules..
By the way, I am only doing a prototype run with 50k+ gates.
Appreciate all the input I can get..
Yarrow
Yarrow
