Stand alone PIC copier/programmer ?
ful babu
Full Member level 3
Full Member level 3
Singapore
pic copier
any one have any schematic / idea ?
thx
Mike K8LH
Full Member level 2
Full Member level 2
Michigan, USA
alone pic
I've designed a couple home-brew high voltage programmers with serial port connection to a PC and the circuitry is simple enough... One programmer was 18F2320 based and the other was 16F88 based... Basically you need circuity for switching VDD and VPP to the target and for toggling target PGC and PGD pins using the commands and specifications outlined in the Programming Specifications document for that particular target device... Power and switching circuit examples are everywhere... Look at the programmer schematics on the www.ic-prog.com site and be sure to check out the ICD2 clone schematic on Lothar Stolz's stolz.de.be web site... I believe there are a few schematics on this forum as well...
Building a 'stand alone copier' is another matter and circuitry will depend on how much data you need to buffer or store from the 'source' PIC... If you need the capability to copy most PIC flash devices, you're going to need to buffer 64-Kbytes (there are a few PIC devices with more than 64-Kbytes or 32-Kwords of flash memory)... You could use an 8-pin 64-Kbyte I2C serial EEProm like the 24LC512 but I think you'd find it would take several minutes to write a full 64-Kbytes to it... You might also consider using one or two 8-pin 32-Kbyte I2C serial RAMs like those from RamTron which would be considerably faster and retain data much like an EEProm...
Good luck with your project... Regards, Mike
ful babu
Full Member level 3
Full Member level 3
Singapore
pic programmer standalone memory
Mike, i'm afraid u misunderstood my 'stand alone programmer' part, i meant, i need a programmer which will not be connected to a pc while programming a pic, i.e. a mobile device tat can flash s pic through icsp
thx
Mike K8LH
Full Member level 2
Full Member level 2
Michigan, USA
eeprom copier ic copier schematic
Sorry, I thought I understood your requirements... I was simply describing my RS232 programmers for you in terms of 'power' and 'switching' circuit examples that I suspect would be required in almost any ICSP programmer...
I suspect your 'stand-alone programmer' would have an LCD display and push-buttons, yes, no? And you would still need circuitry to switch target VDD, VPP, PGC, and PGD? And you would still need memory to capture 'source' PIC code, eeprom, idloc, and config data? Is that a fair assumption?
Best regards, Mike
ful babu
Full Member level 3
Full Member level 3
Singapore
pic copier schematics
LCD ?? not necessary, lemme explain a bit more , firstly i'll copy my hex into my programmer. then i take the programmer and can copy tat hex into mcu thru icsp as many time as i want. for indication tat copy is finished led can b used
this can be helpful when u need to update the hex frequently in industry and u dont want to use a laptop/pc for icsp flash, a stand alone copier will do the same th
i belive made u understand
thx
creative_35
Full Member level 1
Full Member level 1
Under Mango Tree
pic to pic copier
me also need such a programmer wich can upload hexfile from pic/eeprom to another pic without using a pc.
