STAMP model for DDR SDRAM?
jkfoo
Member level 1
.lib stamp
Has anyone familiar with or ever come across a STAMP model for DDR SDRAM?
eternal_nan
Full Member level 3
eternity
You can't check DDR SDRAM interface timing using
STAMP models, or any other Primetime models for
that matter. In order to get good results the IO timing needs to be simulated using a good model
of the bonding wire, package trace and board trace
behaviour, using spice in order to determine if the
IO timing is met. Primetime is meant to be used for
on chip timing mainly, certainly not fast interfaces
like DDR SDRAM.
sri1502
Newbie level 3
Hi
I also heard few people talking about stamp model or .lib model to check DDR timing. I haven't come across anyone who actually did it successfully.
I also attempted to create a stamp model or some kind of model to check DDR io timings, I was not successful too, so I ended up checking in a traditional way
Let me know if you are interested to know the problems I faced?
