Stacking of MOS devices
Prashanthanilm
Full Member level 5
Hi All,
What is the pron and cons of stacking the pMOS and nMOS device?.
Eg:
Conisder an inverter design.
What will the the ouput when:
1.There are 5 pMOS and nMOS
2.There are 10 pMOS and nMOS
3.There are 15 pMOS and nMOS
All the pMOS and nMOS are in series.
Any help would be really appreciated
Thank you,
Prashanth
Stacking would give a cascoding type effect. This would give higher gains.
But the leakage currents of each transistor adds up and after a few levels of stacking you would not see any improvement.
What is meant by this? whether it will be same as before?.
And whether it will function as inverter both Electrically and functionally??
I have not done this for an inverter. I have checked this for an analog common source amplifier type circuit. As you increase the stack, the output impedance increases as expected for a few levels and then stops increasing. This is when the substrate leakage current becomes comparable to the actual current in the circuit.
In an inverter I expect a similar behaviour.
Hi Nitish,
Thank you.
I believe that with 2 stack devices the leakage decreases.
But what if I go on increasing the stack.
In the case of inverter, will you tell that whether it will function as inverter with 10stack pMOS and nMOS?
Sorry dude, I cannot answer that. You can try it yourself and see what happens.
You would need a lot of voltage headroom to keep each transistor in the correct region of operation.
