Stack Up & Via Combinations
bert_kak
Member level 5
Philippines
Attached here is the chip that I'm designing right now and I need some suggestion for layer stack up that I can use for this chip & blind & buried via layer combinations. Thank you.
You probably want to use a blind buried layer stack using the following for fanout:
hole size 5mils +2/-5
Pad size 11.81 mils
For buried you can use whatever is reasonable.
eda
