STA issue about clock gating
andy.huang
Newbie level 3
i used design compiler to synthesis a clock gating circuit automatically.
the clock path is : clk(create clock) -> latch -> DFF/CP
and there comes a problem, the DFFs connected by the gated clock are all un-constraint with the reason "no-clock",
does it the clock constraint cannot pass latch ? how can i solved this issue , thanks.
slutarius
Full Member level 5
You have to check the posibility of your project to use latch in the design.
Secondly, check the enable signal of the latch whether it is fixed to LOW or not.
andy.huang
Newbie level 3
thanks for reply.
i checked, latch is allowed for clock gated, and its enable pin comes from combination logic
slutarius
Full Member level 5
Check the setting in tool behavior about clock signal propagation. When it is OFF, clock can not go through sequential device like latch cells.
