I don't know what process STM32 and the first generations of LM Stellaris use, but LM says the 4th generation Stellaris use 130nm:bobsanjose said:where did you get your information of ST using a 90 nm Flash process? Too much science fiction!bobcat1 said:The power consumption of the LM3s is higher then the STM 32 since it use the 250nm process and the STM32 use 90nm process
In deed ST is using a smaller process than Luminary but the difference is only 1 generation (250 - 90 would be 4 generations).
Luminary Micro Continues its Leadership with the 4th Generation of Stellaris Microcontrollers
Nine New ARM Cortex-M3-based Microcontrollers Unveiled in Low Power 130nm Technology
The new Stellaris family members further extend the industry’s largest ARM-based microcontroller product line by adding higher performance with speeds up to 100 MHz and lower operating power with 130nm low power technology.
