#include <18F2620.h>
#include <stdio.h>
#fuses INTRC_IO,NOWDT,NOPROTECT,NOLVP,NOPUT, NOPBADEN
// Set Speed to 4Mhz
#use delay(clock=4000000)
// Sonar
#use rs232(baud=9600, stop=2, parity=N, xmit=PIN_B2, rcv=PIN_C7, STREAM=Sonar)
// PC
#use rs232(baud=9600, xmit=PIN_B4, rcv=PIN_B3 ,STREAM=PC)
int range,
sonar_address = 0x00, //sonar address (factory default)
sonar_command = 0x54; //Enable Real Ranging Mode command '0x54' for...
//Result in centimeters & automatically Tx range back to...
//controller as soon as ranging is complete
void main(void)
delay_ms(100); //startup delay
while(true)
fputc(sonar_address, Sonar); //Sonar address '0'
fputc(sonar_command, Sonar); //data 0x54
while(!kbhit(Sonar)); //wait for char in USART buffer
range = fgetc(Sonar); //dump range in variable
fprintf(PC,"Range is %u cm\n\r",range);
delay_ms(250);
