Square wave inverter cct not working plz help
mugheesnawaz
Member level 1
Member level 1
i want to make a 100w square wave inverter to drive a resistive load.power rating of inverter isn't an absolute criteria.firstly it isnt working.i have followed a circuit from internet but it isnt working.kindly help me figure out.
i have attached cct diagram and proteus design file
inverter.pngView attachment inverter.rar
Can you define not working? I would not drive two power FETs directly from a C-MOS 4000 device. I would require a gate drive IC in the way to drive them properly.
Rob.
Your circuit is almost the same as mine. Mine works fine and since the frequency is so low then a gate driver IC is not needed.
Not many products today work properly when fed a squarewave.
this is a basic circuit, why it should not work?
replace the IC and Mosfets and see
