Square to Sine wave Converter
saeed_pk
Full Member level 4
Islamabad, Pakistan
square wave to sine wave converter
Hi All,
I am Making a function generator i need a circuit based on an OP-AMP that converts square waveform to sine waveform
please help
reply schematic
square to sine wave converter
Dear,
please send more information such as frequency range,....
Good Luck.
square to sine converter
Use multipole active low-pass filter with 3dB cut-off frequency < 2 x Maximum input frequency of the square wave ..
The output of, for example, 3-pole (or 5-pole) LPF filter should be almost "pure" sine wave ..
Regards,
IanP
square wave to sine wave converter circuit
First make from the square wave a triangle wave, using an integrator, than use a LPF (low pass filter) to filter the triangle wave into a sine wave. This is the fastest way to do this !. If you only use a LPF you need more components, since you need to filter more (higher order).
Paul.
square to sine wave
isnt integrator == LPF
triangle to sine wave converter
Partly true... but if he is making an function generator he must have triagle wave first, so take that as a basis to make a sine and NOT a square.
Paul.
square to sine
R in series tank LC will help as pulsating sq fed to LC circuit will create sine wave.
sq. wave is needed since all practical LC are lossy.
hope u got the ckt. R + (parallel LC grounded) with input sq.wave at R and o/p at R & tank joint.
sine wave to square wave converter
Paul.
Just to add:
Filter specifications could be relaxed if you could cut-off with some limiting circuit top and bottom of triangles (i.e to make trapezoids) before filtering, because then you would have less high frequency components.
