Hello,
This is the code of Square Root from the website -->
https://www.cs.umbc.edu/portal/help/VHDL/samples/sqrt8.vhdl
I can't understand it at all so I have some questions...
1.- If its an sqrt8 bits , why is using at the first entity (Sm) only 6 different signals, 4 in and 2 out?
2.- Architecture is using another 6 signals...why? and what it means this line for example: t011 <= (not x) and y and b;
Ofcourser if I can't understand the first Entity and Architecture I cannot understand the others
Thanks guys
-- sqrt8.vhdl unsigned integer sqrt 8-bits computing unsigned integer 4-bits
-- sqrt(00000100) = 0010 sqrt(4)=2
-- sqrt(01000000) = 1000 sqrt(64)=8
library IEEE;
use IEEE.std_logic_1164.all;
entity Sm is -- subtractor multiplexor
port ( x : in std_logic;
y : in std_logic;
b : in std_logic;
u : in std_logic;
d : out std_logic;
bo : out std_logic);
end Sm;
architecture circuits of Sm is
signal t011, t111, t010, t001, t100, td : std_logic;
begin -- circuits of Sm
t111 <= x and y and b;
t010 <= (not x) and y and (not b);
t001 <= (not x) and (not y) and b;
t100 <= x and (not y) and (not b);
bo <= t011 or t111 or t010 or t001;
td <= t100 or t001 or t010 or t111;
d <= td when u='1' else x;
end architecture circuits; -- of Sm
library IEEE;
entity psqrt is
port ( P : in std_logic_vector(7 downto 0);
U : out std_logic_vector(3 downto 0));
end psqrt;
architecture circuits of psqrt is
signal zer : std_logic := '0';
signal one : std_logic := '1';
signal x00, x01, x02, x03, x04, x05, u_0 : std_logic;
signal b00, b01, b02, b03, b04, b05 : std_logic;
signal x12, x13, x14, x15, x16, u_1 : std_logic;
signal b12, b13, b14, b15, b16 : std_logic;
signal x24, x25, x26, x27, u_2 : std_logic;
signal b24, b25, b26, b27 : std_logic;
signal x36, x37, u_3 : std_logic;
signal b36, b37 : std_logic;
begin -- circuits of psqrt
-- x y b u d bo
s36: entity work.Sm port map(P(6), one, zer, u_3, x36, b36);
s37: entity work.Sm port map(P(7), zer, b36, u_3, x37, b37);
s24: entity work.Sm port map(P(4), one, zer, u_2, x24, b24);
s25: entity work.Sm port map(P(5), zer, b24, u_2, x25, b25);
s26: entity work.Sm port map(x36 , u_3, b25, u_2, x26, b26);
s27: entity work.Sm port map(x37 , zer, b26, zer, x27, b27);
s12: entity work.Sm port map(P(2), one, zer, u_1, x12, b12);
s13: entity work.Sm port map(P(3), zer, b12, u_1, x13, b13);
s14: entity work.Sm port map(x24 , u_2, b13, u_1, x14, b14);
s15: entity work.Sm port map(x25 , u_3, b14, u_1, x15, b15);
s16: entity work.Sm port map(x26 , zer, b15, zer, x16, b16);
s00: entity work.Sm port map(P(0), one, zer, zer, x00, b00);
s01: entity work.Sm port map(P(1), zer, b00, zer, x01, b01);
s02: entity work.Sm port map(x12 , u_1, b01, zer, x02, b02);
s03: entity work.Sm port map(x13 , u_2, b02, zer, x03, b03);
s04: entity work.Sm port map(x14 , u_3, b03, zer, x04, b04);
s05: entity work.Sm port map(x15 , zer, b04, zer, x05, b05);
u_0 <= not b05;
u_1 <= not b16;
u_2 <= not b27;
u_3 <= not b37;
U(0) <= u_0;
U(1) <= u_1;
U(2) <= u_2;
U(3) <= u_3;
end architecture circuits; -- of psqrt
