square root function in embedded system using C
mohamed.elsabagh
Full Member level 2
i need a function in embedded c to calculate square root of a number using microcontroller
What compiler are you using?
Most compilers come with a math library.
Look in the include directory of the compiler for 'math.h'
If your compiler uses math.h then sqrt() is the function you need.
http://www.java2s.com/Code/C/math.h/sqrtreturnsthesquarerootofnum.htm
http://www.codecogs.com/reference/computing/c/math.h/sqrt.php
But are you sure about it? Because normally math.h is to be avoided in embedded systems because of execution time and code size produced by it. Especially if you take under consideration that this function takes a double as argument. You could also take a look at the below reference, where the author presents a couple of fast algorithms to calculate the square root of an integer.
http://www.codecodex.com/wiki/Calculate_an_integer_square_root
Hope this helps,
Alexandros
Sometimes you can 'cheat' and just store a look-up table ; ) It's fast but consumes ROM of course.
I once wanted to draw arbitrary circles on an LCD and given the dimensions of the LCD, my lookup
table was acceptable, because I knew that only circles or arcs up to a certain dimension could be drawn on the LCD.
