- Joined
- Jul 4, 2009
- Messages
- 16,608
- Helped
- 5,158
- Reputation
- 10,349
- Reaction score
- 5,233
- Trophy points
- 1,393
- Location
- Aberdyfi, West Wales, UK
- Activity points
- 140,508
I post elsewhere is about needing a heat sink but not using metal. One of the ideas presented was to use oil to conduct heat away and it piqued my interest. I invite comment from others about its merits.
My thoughts:
Good points -
Liquid oil penetrates the places other methods can't reach,
Convection currents in the oil help to disperse the heat widely,
Suitable oils are a good electrical insulator,
Oil can be chemically stable and can have a long lifetime,
They are normally waterproof!
Bad points -
Potentially high dielectric constant,
Potentially high expansion rate, may require some pressure relief method in an enclosed environment,
Properties may be degraded if contaminated, leaky capacitors for example,
Possibly flammable if overheated or ignited,
May react with plastics, including the enclosure.
I appreciate oil is widely used as a coolant in power transformers so I'm thinking of small scale applications here. Has anyone tried using it as an alternative to metal heat sinks? Maybe the final heat radiating surface is the limiting factor, its difficult to fit fins to oil!
Brian.
My thoughts:
Good points -
Bad points -
Brian.
