I'm designing an isolated current feedback chain for a digitally controlled amplifier. This circuit is powered from an isolated 12V to 12V 1W dc-dc.
My original concept used an LTC3260 charge pump + dual +/- regulator to generate linear +5V/-5V supplies from the single 12V. Unfortunately it looks like the 50mA available from that chip isn't going to cut it.
The alternative I'm exploring here is to generate a regulated 10V and split it, using a buffered 5V midpoint as the reference for the series of differential amplifier stages that are powered from the 10V. This seems reasonable and not terribly unusual, TI makes the TLE2426 specially designed for this (though I don't see a need to use it).
But am I missing any pros and cons here? One detail is the reference to the outside world (the shunt). This whole circuit is isolated so my choices are to tie the shunt to GND or to the midpoint. Choosing the 5V midpoint centers the shunt at the center of the first amplifier's common mode range, as it would be if I had split supplies, which seems advantageous.
For the midpoint amplifier I'm thinking I don't need precision resistors setting the midpoint, small drift would be insignificant, nor do I need a particularly high performance amp. I'm showing it with large caps on the midpoint so I'm not relying on amplifier bandwidth alone to regulate it.
The rest of the picture is that the output goes to a 5V differential ADC with a 4.096 reference. Hence the final differential stage. That ADC will have its own 5V regulator from the 12V. I'm using the NXJ1 series 1W isolated supply from murata because of its size.
Dual output 1W isolated supplies exist of course, but real life availability points to either +/-5V, which doesn't leave room for a linear regulator, or +/-12V which cuts available current to ~40mA on each rail.
