spiral inductor simulation by HFSS
myem
Full Member level 2
hfss spiral inductor
How to simulate spiral inductor by HFSS ?
I don't know how to set boundary condition and excitation.
So I am not sure the simulation result correct or not.
Anyone have experience to share with me.
thanks a lot
Alex_IC
Full Member level 2
Russia
inductor simulation in hfss
At first you have to create the 3D model of your spiral, afterwords place exitation as lumped ports and radiation boundary cond. at air box. Use driven terminal solution to calculate S-parameters.
burton
Full Member level 3
Some tricks should be used for the accurate results of spiral inductor in HFSS simulation. It is better to use Ansoft Designer/ IE3D/Momentum, etc, for 2.5D structure.
Azulykit
All over the Map.
Their user's guide for version 10.0 (HFSS)has an example of a spiral inductor analysis. If you can run down a copy you will probably find it useful.
james cook
Member level 4
china
Is it possible to estimate the inductance of a spiral inductor by HFSS? Any formular?
