mannou
Newbie level 3
Hi all,
When i drag an drop a spice file in the dxdesigner, the symbol
generated (for example tlc27m2) generates an error of duplicated
pin when i run a design rule check (they are the power supply pin
because the package contain two ampliop).
The problem is that the symbol is correctly generated in my colleage
project and the simulation works but not in mine (I use PADS 2007.1).
I just can't figure out why.
Thanks for help.
Edit/Delete Message
Thanks for help.
Edit/Delete Message
